Questions about Wireless Networking
batunkhal
Community Member
So I am relatively new to professional IT. I have been given control of a ton of things with the company I am with. One of those is our Wireless Network. We are not a huge company. About 200 in office workers total. We have 4 main buildings containing the bulk of those employees and a few warehouse with 2-5 people in them. Currently we have one access point deployed in each building which seems to give enough coverage for the people in them. I have been focused on getting the new APs up and running with the WLC as when I came on with the company that had not been done yet. As I am past that now I am working to get the deeper settings configured on the WLC. One of the things I am a bit foggy on is CleanAir. I have had a few people I know that work in tech rave about it to me. I have been reading up on it and it seems like you need a dedicated CleanAir AP that does not transmit for the network. This seems like it doesn't fit our need. Mostly looking for confirmation here if I am correct on this. My other question here is does RRM take care of some of the same things in a more limited way without the extra monitors? Currently we have one AP per location and each AP is in a separate WLAN with its own VLAN. Given that these locations are pretty far apart would it be feasable and/or a good idea to merge these all into a single network with a single SSID so if someone is traveling in the company their devices will link up at all locations with no additional config. And finally can someone link a guide or reference to setting a guest network that is isolated from the internal network? I will be honest that I have not even done a cursory google search on this issue yet as it is a back burner issue for me at this time.
Leo Laohoo
If you do not know what to do, get a reputable systems integrator and shadow them.
Like @Leo Laohoo said, you better contact one of Cisco SI partner in your area to get done with wifi coverage survey and proper solution.
Good luck
KB
patoberli
As my colleagues already mentioned, a professional integrator can help you here a lot.
You did not write if you use a C9800 WLC or one of the older series. In any case, this document has a lot of knowledge, but a few chapters require a deeper understanding into Wi-Fi to not break something:
https://www.cisco.com/c/en/us/products/collateral/wireless/catalyst-9800-series-wireless-controllers/guide-c07-743627.html
There is also an older one for the older series WLC (which have a completely different software and interface).
https://www.cisco.com/c/en/us/td/docs/wireless/controller/technotes/8-6/b_Cisco_Wireless_LAN_Controller_Configuration_Best_Practices.html
