Radio interface Oper Status Down
blackswans
Level 6
Level 6
Some of our AP's oper status are getting down. Their admin status are enabled but why they are getting down? Even I reboot the AP they are still down.
Our software version is : 7.5.102.0
Controller 5508
Thanks.
11 Replies 11
George Stefanick
What radio is it and do all the access points on the controller show the same ?
What type of ap ?
Sandeep Choudhary
Check these:
1. Choose Wireless > 802.11a/n or 802.11b/g/n > Network
Select the 802.11a (or 802.11b/g) Network Status check box to enable the 802.11a or 802.11b/g band.
2. Wireless > Access Points > All APs then click on specific AP and make sure admin status is enable.
if you are using Power INjector then
Go to Wireless > Access Points > All AP’s > Click on specific AP then go to  Advanced and check the Power Injector state.
If still fails to come up then paste the output of these commands:
1. WLC: sh sysinfo; and
2. AP: sh version
Abhishek Abhishek
What kind of wireless NIC are you using?
How was it set up?
Ordinarily, eth interfaces are typically wired, not wireless.
Aside from those anomolies,
Research your NIC
Consider alternate drivers
Reboot the AP now and maybe regularly
Consider replacing the AP
Ali Aqrabawi
many reasons  causes the radio down , can you provide logs ? both radios go down ? or one of them ?
Leo Laohoo
Hmmmmm ... All the radios or just one radio?
I'd be checking the Regulatory Domain of the APs and make sure they match with the Country settings of the WLC.
Ali Aqrabawi
yeah why not
Sent from Cisco Technical Support Android App
blackswans
Level 6
Level 6
Only two AP and only the 5Ghz is down. Reg domain is correct and same with the others.
Can you please post the output to the following commands:
1.  WLC:  sh sysinfo;
2.  AP:  sh version
Sandeep Choudhary
provide more info.... as me and leo asked in our respective posts.
sh version -- From AP
sh sysinfo -  From WLC
may be u have multicountry configured on WLC ?
Scott Fella
I just had an issue with that with v7.4.110.0 and some 2602's. 1142's were fine. Seemed like when I bounced the WLC or mad a change to RRM some of the AP's would disassociate and come back to the WLC. What I noticed is a few would have their radios down and I have to manually disable and enable to get then working again. I upgraded to v7.4.121.0 and seemed to be a bit more stable but only had an issue with one out if 325.
v7.5 is a deferred code so you might want to upgrade to v7.6 or downgrade to v7.4.121.0.
-Scott
