Radio Interface Reset and Shutdown Frequently
Bell Kun
As recently new office from end-Sept, we have found that the radio interface reset very frequently which has been  happening about over 15 times within 8 weeks for one AP on average. Some of  those (3 AP so far) got the radio interface down eventually and we need to  reload the AP to make it up again.
the AP model is AIR-LAP1142N-N-K9 and the IOS version is c1140-k9w7-mx.124-21a.JA1. Power supply is made from the PoE switch c2960s. Is there any issue related to IOS? or some other factors may cause the issue happen? Any debug command can show the status of AP? Please advice.
Surendra BG
Upgrade the software to 12.4(21a)JY and see if we are able to reproduce the issue..
Surendra
Surendra BG
10 Replies 10
Surendra BG
Surendra
Surendra BG
Hi Surendra,
Other than IOS, will this radio interface reset and shutdown issue affect by the nearby AP which is not belongs to the same office.
Scenario:
The new office gets 2 floors. One is 5/F which has installed 9 APs with different channels and another one is 6/F which has installed 6 APs with different channels as well. We found that there are many events “%DOT11-4-MAXRETRIES: Packet to client reached max retries, removing the client” logged on 5/F and 6/F AP.
We also found that the radio interface reset very frequently which has been happening about over 15 times within 8 weeks for one AP on average. Some of those (3 AP so far) got the radio interface down eventually and we need to reload the AP to make it up again.
Is/ are there any possibility caused by otherenvironmental factors? Please advise.
Best regards,
Bell
NO!! coz of interference the radios will never go to RESET DOWN status unless we are using ROOT - NON ROOT bridge more..
Surendra
Surendra BG
upgrade and let me know how this works out.. and lemme know how if this answered your question
Surendra
Surendra BG
tried upgrading?? are we still facing the issue??
Surendra
Surendra BG
Not yet. We are just scheduling the maintenance windows as there are 15 APs totally.
I will update you here when the update is done.
Hi Surenda,
We have just upgraded the latest IOS for the AP. In this moment, the status seems fine without any interface shutdown in sudden.
We will keep this into monitoring status.
Thanks for your info and Happy New Year!!!
B.regards,
Bell
Hi Bell,
Happy new year!!
thats nice to hear that the issue is not reproducible!! Please dont forget to mark the post as answered if that helped you in getting the issue resolved!!
Surendra
Surendra BG
Eduardo Cesaro
Checks this question and verify to help us https://supportforums.cisco.com/message/3214087
I agree with Surendra.  Radio interference cannot and will not reset a radio interface.
