Radio problem
fkatsumi1
Visitor
Hi. I'm wondering if anybody can tell me if this is a software or hardware probelm.
I'm getting this error on one of my AP1230 event log. Everything looks good but the Radio0 does not come up. I have reset the hardware to factory default. I also put on the latest firmware 12.3.8JAE.
Interface Dot11Radio0, failed - Radio configuration failed, cmd 1 (0,0,0) status 7F01 (1,0,0)
Here is the configuration
version 12.3
no service pad
service password-encryption
hostname AKWL4
enable secret xxx
ip subnet-zero
no aaa new-model
dot11 ssid AKWL4
authentication open
guest-mode
username Cisco password xxx
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption key 1 size 128bit xxx transmit-key
encryption mode wep mandatory
ssid AKWL4
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio1
no ip address
no ip route-cache
ssid AKWL4
speed basic-6.0 9.0 basic-12.0 18.0 basic-24.0 36.0 48.0 54.0
station-role root
bridge-group 1
interface FastEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
bridge-group 1
hold-queue 160 in
interface BVI1
ip address dhcp client-id FastEthernet0
no ip route-cache
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
control-plane
bridge 1 route ip
line con 0
line vty 0 4
login local
end
5 Replies 5
Benjamin Solero
The error typically indicates either a mismatched carrier set between the radio and AP programming OR faulty hardware. What do you see in the output of 'show ver' and 'show controller dot11radio 0'?
Ben
Thanks for your reply and help. I'm not sure what I should be looking for but all the hardware should be for America. Here are the outputs.
#show ver
Cisco IOS Software, C1200 Software (C1200-K9W7-M), Version 12.3(8)JEA, RELEASE S
OFTWARE (fc2)
Copyright (c) 1986-2006 by Cisco Systems, Inc.
Compiled Wed 23-Aug-06 16:42 by kellythw
ROM: Bootstrap program is C1200 boot loader
BOOTLDR: C1200 Boot Loader (C1200-BOOT-M), Version 12.2 [BLD-argon 102]
AKWL4 uptime is 2 hours, 13 minutes
System returned to ROM by reload
System image file is "flash:/c1200-k9w7-mx.123-8.JEA/c1200-k9w7-mx.123-8.JEA"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
cisco AIR-AP1230A-A-K9 (PowerPC405GP) processor (revision 01) with 15138K/12
36K bytes of memory.
Processor board ID FOC070700GR
PowerPC405GP CPU at 196Mhz, revision number 0x00C4
Last reset from reload
1 FastEthernet interface
2 802.11 Radio(s)
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 00:0B:FD:AB:8C:53
Part Number : 73-8704-01
PCA Assembly Number : 800-23211-01
PCA Revision Number : 01
PCB Serial Number : FOC070700GR
Top Assembly Part Number : 800-23209-01
Top Assembly Serial Number : FHK0709J0A3
Top Revision Number : 01
Product/Model Number : AIR-AP1230A-A-K9
Configuration register is 0xF
I don't know how or why but the carrier set is ??? as below. Could this be the problem?
Thanks.
Fred
#show controller dot11radio 0
Radio AIR-MP31G, Base Address 0011.21fd.6870, BBlock version 0.00, Software vers
ion 6.00.1
Serial number: AMB0821D45B
Number of supported simultaneous BSSID on Dot11Radio0: 8
Carrier Set: Unknown (???)
Uniform Spreading Required: No
Current Frequency: 0 MHz Channel 0
Allowed Frequencies: 2412(1) 2417(2) 2422(3) 2427(4) 2432(5) 2437(6) 2442(7) 244
7(8) 2452(9) 2457(10) 2462(11)
Listen Frequencies: 2412(1) 2417(2) 2422(3) 2427(4) 2432(5) 2437(6) 2442(7) 2447
(8) 2452(9) 2457(10) 2462(11) 2467(12) 2472(13) 2484(14)
Beacon Flags: 0; Beacons are disabled; Probes are disabled
Current CCK Power: 100 mW
Allowed CCK Power Levels: 1 5 10 20 30 50 100
Current OFDM Power: 30 mW
Allowed OFDM Power Levels: 1 5 10 20 30
Allowed Client Power Levels: 1 5 10 20 30 50 100
ERP settings: short slot time.
Neighbors in non-erp mode:
This is the error I expected to see if the hardware (either AP or radio) was faulty. Since the AP and Radio are both -A, the error indicates that either the cookies are corrupt or the radio hardware itself is bad. You can try to reseat the radio, try this radio in another AP, or another radio in this AP. Maybe you can narrow it down to the AP or radio that way. However, I suspect you'll need the AP replaced. 😞
Sorry I couldn't help further, but let me know the outcome.
-Ben
I am having similar problems. I cant tell if the radio is working or if it is some other issue. I have about 800 1310 APS and some come back as faulty. So when I troubleshoot over half of them are related to configuration issues. The other , everything appears to be alright yet the radio wont associate.
