Radio reset cause
Noovi
Level 4
Level 4
Hello Guys,
I am having once cisco 5520 WLC with image running 8.10.185.3.
in one of AP i observerd user disconnection and when i saw in AP CLI i saw this.
Anyone knows if it is bug or any config issue. I have set DCA channel width to 'Best', so want to know if it is causing this issue.
Nov 27 00:04:28 kernel: [*11/27/2023 00:04:28.9074] 1:change to DFS channel 52, CAC for 60 seconds.
Nov 27 00:04:28 kernel: [*11/27/2023 00:04:28.9316] DOT11_DRV[1]: Stopped Radio 1
Nov 27 00:04:28 kernel: [*11/27/2023 00:04:28.9380] deinit DFS SM since radio is stopped before last CAC expired
Nov 27 00:04:28 kernel: [*11/27/2023 00:04:28.9549] DOT11_DRV[1]: DOT11_DRV[1]: set_channel Channel set to 52
Nov 27 00:04:29 kernel: [*11/27/2023 00:04:29.7779] 1:change to DFS channel 52, CAC for 60 seconds.
Nov 27 00:04:29 kernel: [*11/27/2023 00:04:29.8385] DOT11_DRV[1]: Started Radio 1
Nov 27 00:05:29 kernel: [*11/27/2023 00:05:29.5322] event-> CAC_EXPIRY_EVT
Nov 27 00:05:29 kernel: [*11/27/2023 00:05:29.6905] chatter: wl1: Beacon rate info: Previous: 252052736 Current: 251856128
Nov 27 00:05:29 kernel: [*11/27/2023 00:05:29.6905] chatter: wl1: Beacon PID : Previous: 6 Current: 3
Nov 27 00:25:02 kernel: [*11/27/2023 00:25:02.4139] DOT11_DRV[1]: DOT11_DRV[1]: set_channel Channel set to 60, CSA count 6
CAC for 60 seconds.nel: [*11/27/2023 00:25:02.9858] 1:change to DFS channel 60, --More--
Nov 27 00:25:03 kernel: [*11/27/2023 00:25:03.0422] DOT11_DRV[1]: Stopped Radio 1
Nov 27 00:25:03 kernel: [*11/27/2023 00:25:03.0486] deinit DFS SM since radio is stopped before last CAC expired
Nov 27 00:25:03 kernel: [*11/27/2023 00:25:03.0649] DOT11_DRV[1]: DOT11_DRV[1]: set_channel Channel set to 60
Nov 27 00:25:03 kernel: [*11/27/2023 00:25:03.8734] 1:change to DFS channel 60, CAC for 60 seconds.
Nov 27 00:25:03 kernel: [*11/27/2023 00:25:03.9340] DOT11_DRV[1]: Started Radio 1
Nov 27 06:59:34 kernel: [*11/27/2023 06:59:34.0287] *** RSN ERROR: Received a data frame when no keys are plumbed
Nov 27 06:59:34 kernel: [*11/27/2023 06:59:34.2575]
Nov 27 07:27:24 kernel: [*11/27/2023 06:59:34.2576] *** RSN ERROR: Received a data frame when no keys are plumbed
Nov 27 07:27:24 kernel: [*11/27/2023 07:27:24.3223]
Nov 27 07:27:24 kernel: [*11/27/2023 07:27:24.3224] *** RSN ERROR: Received a data frame when no keys are plumbed
Nov 27 07:27:24 kernel: [*11/27/2023 07:27:24.4232]
Nov 27 07:27:24 kernel: [*11/27/2023 07:27:24.4232] *** RSN ERROR: Received a data frame when no keys are plumbed
Nov 27 07:27:24 kernel: [*11/27/2023 07:27:24.4449]
Nov 27 07:27:24 kernel: [*11/27/2023 07:27:24.4449] *** RSN ERROR: Received a data frame when no keys are plumbed
Nov 27 07:27:24 kernel: [*11/27/2023 07:27:24.4606]
Nov 27 07:27:24 kernel: [*11/27/2023 07:27:24.4606] *** RSN ERROR: Received a data frame when no keys are plumbed
6 Replies 6
Leo Laohoo
Do not worry about APs or radios crashing because there is a very, very long list.
But user faces disconnection for that time.
What is the model of the AP in question?
##- AP model is 3802 -##
Vineet Shine
Orange Restricted
____________________________________________________________________________________________________________
Ce message et ses pieces jointes peuvent contenir des informations confidentielles ou privilegiees et ne doivent donc
pas etre diffuses, exploites ou copies sans autorisation. Si vous avez recu ce message par erreur, veuillez le signaler
a l'expediteur et le detruire ainsi que les pieces jointes. Les messages electroniques etant susceptibles d'alteration,
Orange decline toute responsabilite si ce message a ete altere, deforme ou falsifie. Merci.
This message and its attachments may contain confidential or privileged information that may be protected by law;
they should not be distributed, used or copied without authorisation.
If you have received this email in error, please notify the sender and delete this message and its attachments.
As emails may be altered, Orange is not liable for messages that have been modified, changed or falsified.
Thank you.
JPavonM
If there is only 1-AP at that location then best avoid DFS channels, if there are more than one, then review your design to provide redundncy with 2nd signal option above -68bDm.
Noovi
Level 4
Level 4
Actually there are more than 8-10 APs per floor. For now we have decided to use RF profile with 40Mhz DCA and with non-DFS channel.
