Radio resets when enabling new SSID
azore2007
Hello everyone
Running vwlc 7.3.101 and encountered a smaller issue.
When you enable / disable a SSID, all AP's reset their radio interfaces... causing everyone to drop their connection.
Is this intentional?
Scott Fella
I have never ran into that issue at all. I make changes to specific eland and that doesn't affect any other wlans nor does it glitches the ap radios.
I do this all the time too.
-Scott
maldehne
APs shouldn't rest their radios upon enabling or disabling ssid from WLC.
If the AP is autonomous , then adding or removing SSID to-from the radio interface causes it reset.
attach show run-config
highlight the APs that had resetted.
Please Don't to rate correct answers
azore2007
Yeap, thats what I thought, couldnt remember having the AP's resetting their interfaces when enable/disable SSID'n
I will open a TAC case
I'll post the solution when I get it
Thanks for the replies
Clarification question.  Are you using AP groups?
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
HTH,
Steve
