Radius Based SSID Access Control
mnlatif
Level 7
Level 7
We are trying to deploy RADIUS Based SSID control using Micrsoft 2003 IAS Service. Access Points are running IOS 12.2(13)JA1.
We are trying to return the attribute 1 with "Value" set to
ssid = test
However when a user connects using SSID "test", he is denied access. On the IAS logs i can see that "Access-Accept" was sent to the Access Point, but in Access Point logs i see the "Authentication Failed" message.
If we remove the Attribute from the User Profile, then User can connect fine.
Are we using the in-correct format for the attribute ?
Any Help.
naman
b.hsu
Level 11
Level 11
