Radius Issue
tpacjer
Level 2
Level 2
i have a user that is only able to use the wireless connection while connected to the LAN. When the user disconnects i am able to see the client assoc but cannot communicated. Any ideas.
manjesin
Level 3
Level 3
Here are few thing which you can check :-
* When it show associated .. do ipconfig on computer ... check if there any ipaddress or not .. if it is not getting ip address .. communication will not take place....
* Assign static ip address for testing .
* If we have the correct ip address ..
Do clear arp on AP once or reboot ..
Then, try to connect again ..
Thanks ..
Pls rate .. it solution works for you so that other can benefit of these steps
manjesin
Level 3
Level 3
Thanks ..
right direction dhcp scope was distributing worng gateway after scope corrected issue was resolved
