RDP issue among WiFi Users
Mehul Halvadia
Hello All,
We have 3500 series WLC with HA configured and 1600, 1700 & 1800 Series Access Points.
Management Team can RDP LAN to LAN and LAN to WLAN but WLAN to WLAN they can not, and we do not have any VLAN & ACL configured.
PLS help to Resolve this RDP issue :: from WLAN to WLAN can be possible.
Thank you..!!
balaji.bandi
This Looks odd for me, may be worth TCP capture (wireshark see what is wrong)
or download small TCP Listner software install and PC try to telnet RDP port check the status
BB
When you say WLAN to WLAN are you talking between SSIDs or within the same SSID?
Do you have P2P Blocking Action on the WLAN set to drop by any chance? if so then traffic not allowed between devices on this WLAN
*****Help out other by using the rating system and marking answered questions as "Answered"*****
Its within the same SSID.
And yes "P2P Blocking Action" is set to DROP. There are two more options 1. Disabled & 2. Forward-UpStream.
which should be Selected..??
