WLAN Authentication using Azure ADDS
Has anyone implemented a design wherein they use Azure ADDS as the primary mode of Authentication to Wireless Access. I'm trying to achieve the following objective
1. SSIDs will be broadcasted by Cisco APs
2. Mode of Authentication will be via Radius NPS (Windows)
3. Within Radius, how can I reference the Azure AD Groups so that I can use it in the NPS Policy.
Thanks 😄
Haydn Andrews
Maybe have a look at: https://docs.microsoft.com/en-us/azure/active-directory-domain-services/tutorial-configure-ldaps
It was listed as a way to integrate Cisco ISE for RADIUS auth
https://community.cisco.com/t5/network-access-control/ise-integration-with-azure-ad/td-p/3805022
*****Help out other by using the rating system and marking answered questions as "Answered"*****
