Rebbot on cisco AIR-AP1852I-N-K9 ARMv7
rulezzz
Hello there firts time posting here.
I have a AP cisco AIR-AP1852I-N-K9 that constantly reboots, went it boots the led stay in green but after a wile it changes to amber,red and green then it reboot. I apply a factory reset to the AP and then I configure a static IP address 192.168.1.1 so I can login to the web interface but then again suddenly reboot, I can post more info if you ask
(Cisco Controller) >show inventory
Burned-in MAC Address............................ **:**:**:**:**:A0
Maximum number of APs supported.................. 25
NAME: "Chassis" , DESCR: "Cisco Aironet 1850 Series Mobility Express"
PID: AIR-AP1852I-N-K9, VID: 8.2.111.0, SN: ************
more info from the boot console:
[*06/21/2016 02:07:51.3368] ethernet_port wired0, ip 192.168.1.2, netmask 255.255.255.0, gw 192.168.1.100, mtu 1500, bcast 192.168.1.255, dns1 0.0.0.0, is_static true, vid 0, static_ip_failover false, dhcp_vlan_failover false
[*06/21/2016 02:08:04.8525] Loading sha2...
[*06/21/2016 02:08:04.8525] Dumpping sha1...
[*06/21/2016 02:08:06.0922] Loading MIC cert and key
[*06/21/2016 02:08:06.0922] Dumpping sha2...
[*06/21/2016 02:08:07.2618] Loading MIC cert and key
[*06/21/2016 02:08:07.2618] /etc/init.d/S80cisco: line 161: /usr/bin/show_skun.lua: not found
[*06/21/2016 02:08:07.2918] Generating key, this may take a while...
[*06/21/2016 02:08:09.9809] Public key portion is:
[*06/21/2016 02:08:09.9809] ssh-rsa AAAAB3NzaC1yc2EAAAADAQABAAABAQC6EFXrTXxv3N1spWv5SkS17ZrfV0etkWOxhO6DSNjJuGCmShCV/iVX545cukgdeDm+/M7A2UFtaMeh+o0ayDcxd71LJBXOMFsyhOga0BwkVGGXBzL0XgUVgoMCP6bI5OLBcDUp+48C8OpdY28bvbLjtrcUrzYIBOXisiAE2BMyKkb7nC+uUH753Tc2LVXLj3UebIqmjL8SxYc+1Bmt1f3R3ZBAOVgBEYefhlVvoych1dwioOCJtx/2SzZhoMQ4Ij3GRfw2+7Fv4RDOnWW5tr9cMTGYnsssLV7/Hspe96r8VY5EtfyXpk2Ymh79YkGgmy1Y8laMQs+rtqRTDGEmaCTP root@m3820568251A8
[*06/21/2016 02:08:09.9809] Fingerprint: md5 7a:15:a5:89:21:5b:6f:8c:fd:71:ce:0c:39:3b:23:4e
[*06/21/2016 02:08:10.0209] pid 2417's current affinity mask: 3
[*06/21/2016 02:08:10.0209] pid 2417's new affinity mask: 1
[*06/21/2016 02:08:10.1009] gzip -dc /etc/wcp.usermodule.template.gz | sed -e 's/__TX_POWER_2G_FILE__/\/radio_fw\/R2.csv/g' -e 's/__TX_POWER_5G_FILE__/\/radio_fw\/R5.csv/g' -e 's/__EVM_POWER_2G_FILE__/\/radio_fw\/EVM_2.csv/g' -e 's/__EVM_POWER_5G_FILE__/\/radio_fw\/EVM_5.csv/g' -e 's/__DOMAIN_2G__/0/g' -e 's/__DOMAIN_5G__/21/g' -e 's/__PRODUCT_ID__/AIR-AP1852I-N-K9/g' -e 's/__AP_TYPE__/48/g' -e 's/__WIRELESS_MAC__/38:20:56:83:B1:40/g' -e 's/__WIRED_MAC__/38:20:56:82:51:A8/g' -e 's/__WIRED1_MAC__/38:20:56:82:51:A8/g' | DMALLOC_OPTIONS=debug=0x4e48503,inter=1000,log=/tmp/wcp.dmalloc.log,limit=40000000 wcpd &
[*06/21/2016 02:08:10.4808] Password for 'Cisco' changed
[*06/21/2016 02:08:11.5405] DOT11_DRV[1]: Init Radio1
[*06/21/2016 02:08:11.5405] DOT11_DRV[1]: wifi1: Failed to get radio priv parameter (op 4234)
[*06/21/2016 02:08:11.5504] wifi1 no private ioctls.
[*06/21/2016 02:08:11.5504] DOT11_DRV[1]: wifi1: Failed to set parameter (op 4283 arg 1)
[*06/21/2016 02:08:11.5504] DOT11_DRV[1]: wifi1 acfg cmd 2 failed for wifi1 errno 19(No such device)
[*06/21/2016 02:08:11.5504] DOT11_DRV[1]: acfg_set_radio_param param 0x200d value 1 failed
[*06/21/2016 02:08:11.5504] DOT11_DRV[1]: acfg_set_radio_param param 0x2017 value 1 failed
[*06/21/2016 02:08:11.5504] DOT11_DRV[1]: wifi1 acfg cmd 16 failed for wifi1 errno 19(No such device)
[*06/21/2016 02:08:11.5504] DOT11_DRV[1]: wifi1 acfg cmd 19 failed for wifi1 errno 19(No such device)
[*06/21/2016 02:08:11.5504] DOT11_DRV[1]: Radio 1 NF_Calibration request failed !
[*06/21/2016 02:08:11.5504] DOT11_DRV[1]: wifi1: Failed to set parameter (op 4176 arg 1)
[*06/21/2016 02:08:11.5504] DOT11_DRV[1]: wifi1: Failed to set parameter (op 4235 arg 1)
[*06/21/2016 02:08:11.5504] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_get_bssid ioctl SIOCGIFHWADDR failed for apr1v0 error No such device
[*06/21/2016 02:08:11.5504] DOT11_DRV[1]: ERROR: Radio BSSID Addr: 00:00:00:00:00:00 does not match with driver BSSID Addr: 38:20:56:83:B1:4F
[*06/21/2016 02:08:11.5504] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_get_bssid ioctl SIOCGIFHWADDR failed for apr1v1 error No such device
[*06/21/2016 02:08:11.5504] DOT11_DRV[1]: ERROR: Radio BSSID Addr: 00:00:00:00:00:00 does not match with driver BSSID Addr: 38:20:56:83:B1:4E
[*06/21/2016 02:08:11.5504] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_get_bssid ioctl SIOCGIFHWADDR failed for apr1v2 error No such device
[*06/21/2016 02:08:11.5504] DOT11_DRV[1]: ERROR: Radio BSSID Addr: 00:00:00:00:00:00 does not match with driver BSSID Addr: 38:20:56:83:B1:4D
[*06/21/2016 02:08:11.5504] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_get_bssid ioctl SIOCGIFHWADDR failed for apr1v3 error No such device
[*06/21/2016 02:08:11.5504] DOT11_DRV[1]: ERROR: Radio BSSID Addr: 00:00:00:00:00:00 does not match with driver BSSID Addr: 38:20:56:83:B1:4C
[*06/21/2016 02:08:11.5504] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_get_bssid ioctl SIOCGIFHWADDR failed for apr1v4 error No such device
[*06/21/2016 02:08:11.5504] DOT11_DRV[1]: ERROR: Radio BSSID Addr: 00:00:00:00:00:00 does not match with driver BSSID Addr: 38:20:56:83:B1:4B
[*06/21/2016 02:08:11.5504] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_get_bssid ioctl SIOCGIFHWADDR failed for apr1v5 error No such device
[*06/21/2016 02:08:11.5504] DOT11_DRV[1]: ERROR: Radio BSSID Addr: 00:00:00:00:00:00 does not match with driver BSSID Addr: 38:20:56:83:B1:4A
[*06/21/2016 02:08:11.5504] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_get_bssid ioctl SIOCGIFHWADDR failed for apr1v6 error No such device
[*06/21/2016 02:08:11.5604] DOT11_DRV[1]: ERROR: Radio BSSID Addr: 00:00:00:00:00:00 does not match with driver BSSID Addr: 38:20:56:83:B1:49
[*06/21/2016 02:08:11.5604] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_get_bssid ioctl SIOCGIFHWADDR failed for apr1v7 error No such device
[*06/21/2016 02:08:11.5604] DOT11_DRV[1]: ERROR: Radio BSSID Addr: 00:00:00:00:00:00 does not match with driver BSSID Addr: 38:20:56:83:B1:48
[*06/21/2016 02:08:11.5604] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_get_bssid ioctl SIOCGIFHWADDR failed for apr1v8 error No such device
[*06/21/2016 02:08:11.5604] DOT11_DRV[1]: ERROR: Radio BSSID Addr: 00:00:00:00:00:00 does not match with driver BSSID Addr: 38:20:56:83:B1:47
[*06/21/2016 02:08:11.5604] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_get_bssid ioctl SIOCGIFHWADDR failed for apr1v9 error No such device
[*06/21/2016 02:08:11.5604] DOT11_DRV[1]: ERROR: Radio BSSID Addr: 00:00:00:00:00:00 does not match with driver BSSID Addr: 38:20:56:83:B1:46
[*06/21/2016 02:08:11.5604] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_get_bssid ioctl SIOCGIFHWADDR failed for apr1v10 error No such device
[*06/21/2016 02:08:11.5604] DOT11_DRV[1]: ERROR: Radio BSSID Addr: 00:00:00:00:00:00 does not match with driver BSSID Addr: 38:20:56:83:B1:45
[*06/21/2016 02:08:11.5604] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_get_bssid ioctl SIOCGIFHWADDR failed for apr1v11 error No such device
[*06/21/2016 02:08:11.5604] DOT11_DRV[1]: ERROR: Radio BSSID Addr: 00:00:00:00:00:00 does not match with driver BSSID Addr: 38:20:56:83:B1:44
[*06/21/2016 02:08:11.5604] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_get_bssid ioctl SIOCGIFHWADDR failed for apr1v12 error No such device
[*06/21/2016 02:08:11.5604] DOT11_DRV[1]: ERROR: Radio BSSID Addr: 00:00:00:00:00:00 does not match with driver BSSID Addr: 38:20:56:83:B1:43
[*06/21/2016 02:08:11.5604] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_get_bssid ioctl SIOCGIFHWADDR failed for apr1v13 error No such device
[*06/21/2016 02:08:11.5604] DOT11_DRV[1]: ERROR: Radio BSSID Addr: 00:00:00:00:00:00 does not match with driver BSSID Addr: 38:20:56:83:B1:42
[*06/21/2016 02:08:11.5604] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_get_bssid ioctl SIOCGIFHWADDR failed for apr1v14 error No such device
[*06/21/2016 02:08:11.5604] DOT11_DRV[1]: ERROR: Radio BSSID Addr: 00:00:00:00:00:00 does not match with driver BSSID Addr: 38:20:56:83:B1:41
[*06/21/2016 02:08:11.5604] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_get_bssid ioctl SIOCGIFHWADDR failed for apr1v15 error No such device
[*06/21/2016 02:08:11.5604] DOT11_DRV[1]: ERROR: Radio BSSID Addr: 00:00:00:00:00:00 does not match with driver BSSID Addr: 38:20:56:83:B1:40
[*06/21/2016 02:08:11.5604] DOT11_DRV[1]: Stop Radio1
[*06/21/2016 02:08:11.5604] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_stop_radio ioctl SIOCGIFFLAGS failed for wifi1 error -1
[*06/21/2016 02:08:11.5604] DOT11_DRV[1]: Failure to Stop radio during Base Driver Initialization
[*06/21/2016 02:08:11.5604] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver is_vap_present ioctl SIOCGIFFLAGS failed for apr1v0 error No such device
[*06/21/2016 02:08:11.5604] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver is_vap_present ioctl SIOCGIFFLAGS failed for apr1v1 error No such device
[*06/21/2016 02:08:11.5704] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver is_vap_present ioctl SIOCGIFFLAGS failed for apr1v2 error No such device
[*06/21/2016 02:08:11.5704] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver is_vap_present ioctl SIOCGIFFLAGS failed for apr1v3 error No such device
[*06/21/2016 02:08:11.5704] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver is_vap_present ioctl SIOCGIFFLAGS failed for apr1v4 error No such device
[*06/21/2016 02:08:11.5704] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver is_vap_present ioctl SIOCGIFFLAGS failed for apr1v5 error No such device
[*06/21/2016 02:08:11.5704] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver is_vap_present ioctl SIOCGIFFLAGS failed for apr1v6 error No such device
[*06/21/2016 02:08:11.5704] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver is_vap_present ioctl SIOCGIFFLAGS failed for apr1v7 error No such device
[*06/21/2016 02:08:11.5704] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver is_vap_present ioctl SIOCGIFFLAGS failed for apr1v8 error No such device
[*06/21/2016 02:08:11.5704] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver is_vap_present ioctl SIOCGIFFLAGS failed for apr1v9 error No such device
[*06/21/2016 02:08:11.5704] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver is_vap_present ioctl SIOCGIFFLAGS failed for apr1v10 error No such device
[*06/21/2016 02:08:11.5704] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver is_vap_present ioctl SIOCGIFFLAGS failed for apr1v11 error No such device
[*06/21/2016 02:08:11.5704] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver is_vap_present ioctl SIOCGIFFLAGS failed for apr1v12 error No such device
[*06/21/2016 02:08:11.5704] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver is_vap_present ioctl SIOCGIFFLAGS failed for apr1v13 error No such device
[*06/21/2016 02:08:11.5804] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver is_vap_present ioctl SIOCGIFFLAGS failed for apr1v14 error No such device
[*06/21/2016 02:08:11.5804] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver is_vap_present ioctl SIOCGIFFLAGS failed for apr1v15 error No such device
[*06/21/2016 02:08:11.5804] DOT11_DRV[1]: mon1 ioctl op=0x8bf2 len=4 failed: 19 (No such device)
[*06/21/2016 02:08:11.5804] DOT11_DRV[1]: set mode_str 11A to mon1 failed
[*06/21/2016 02:08:11.5804] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver is_vap_present ioctl SIOCGIFFLAGS failed for apr1v0 error No such device
[*06/21/2016 02:08:11.5804] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver is_vap_present ioctl SIOCGIFFLAGS failed for apr1v1 error No such device
[*06/21/2016 02:08:11.5804] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver is_vap_present ioctl SIOCGIFFLAGS failed for apr1v2 error No such device
[*06/21/2016 02:08:11.5804] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver is_vap_present ioctl SIOCGIFFLAGS failed for apr1v3 error No such device
[*06/21/2016 02:08:11.5804] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver is_vap_present ioctl SIOCGIFFLAGS failed for apr1v4 error No such device
[*06/21/2016 02:08:11.5804] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver is_vap_present ioctl SIOCGIFFLAGS failed for apr1v5 error No such device
[*06/21/2016 02:08:11.5804] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver is_vap_present ioctl SIOCGIFFLAGS failed for apr1v6 error No such device
[*06/21/2016 02:08:11.5804] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver is_vap_present ioctl SIOCGIFFLAGS failed for apr1v7 error No such device
[*06/21/2016 02:08:11.5804] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver is_vap_present ioctl SIOCGIFFLAGS failed for apr1v8 error No such device
[*06/21/2016 02:08:11.5804] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver is_vap_present ioctl SIOCGIFFLAGS failed for apr1v9 error No such device
[*06/21/2016 02:08:11.5804] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver is_vap_present ioctl SIOCGIFFLAGS failed for apr1v10 error No such device
[*06/21/2016 02:08:11.5804] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver is_vap_present ioctl SIOCGIFFLAGS failed for apr1v11 error No such device
[*06/21/2016 02:08:11.5804] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver is_vap_present ioctl SIOCGIFFLAGS failed for apr1v12 error No such device
[*06/21/2016 02:08:11.5804] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver is_vap_present ioctl SIOCGIFFLAGS failed for apr1v13 error No such device
[*06/21/2016 02:08:11.5804] DOT11_DRV[1]: mon1 acfg cmd 30 failed for mon1 errno 19(No such device)
[*06/21/2016 02:08:11.5804] DOT11_DRV[1]: set_channel Channel set to 36
[*06/21/2016 02:08:11.5804] DOT11_DRV[1]: wifi1 acfg cmd 17 failed for wifi1 errno 19(No such device)
[*06/21/2016 02:08:11.5804] DOT11_DRV[1]: wifi1: Failed to set parameter (op 4242 arg 0)
[*06/21/2016 02:08:11.5904] DOT11_DRV[1]: wifi1: Failed to set parameter (op 4241 arg 0)
[*06/21/2016 02:08:11.5904] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_get_bssid ioctl SIOCGIFHWADDR failed for apr1v0 error No such device
[*06/21/2016 02:08:11.5904] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_get_bssid ioctl SIOCGIFHWADDR failed for apr1v1 error No such device
[*06/21/2016 02:08:11.5904] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_get_bssid ioctl SIOCGIFHWADDR failed for apr1v2 error No such device
[*06/21/2016 02:08:11.5904] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_get_bssid ioctl SIOCGIFHWADDR failed for apr1v3 error No such device
[*06/21/2016 02:08:11.5904] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_get_bssid ioctl SIOCGIFHWADDR failed for apr1v4 error No such device
[*06/21/2016 02:08:11.5904] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_get_bssid ioctl SIOCGIFHWADDR failed for apr1v5 error No such device
[*06/21/2016 02:08:11.5904] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_get_bssid ioctl SIOCGIFHWADDR failed for apr1v6 error No such device
[*06/21/2016 02:08:11.5904] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_get_bssid ioctl SIOCGIFHWADDR failed for apr1v7 error No such device
[*06/21/2016 02:08:11.5904] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_get_bssid ioctl SIOCGIFHWADDR failed for apr1v8 error No such device
[*06/21/2016 02:08:11.5904] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_get_bssid ioctl SIOCGIFHWADDR failed for apr1v9 error No such device
Cryptographic library self-test....
Testing SHA1 Short Message 1
Testing SHA256 Short Message 1
SHA1 POST PASSED
passed!
I appreciate any competent about.
Try to upgrade in ROMMON, but first wait for ~10 minutes to see if it stays stable:
https://community.cisco.com/t5/wireless-mobility-documents/access-point-rommon-recovery-ap-prompt-recovery-example/ta-p/3119495
Any newer release (I recommend 8.5.151.0) should fix the issue. Alternatively open an RMA, I'm pretty sure this is a warranty reason.
11 Replies 11
Leo Laohoo
Is the AP running 8.2.111.0?
If it is, upgrade the firmware and see if improves things.
Hello Leo thanks for answer, yes the AP its running v 8.2.111.0
Whats version should I install in the AP, what happen if I install the firmware and reboots in the middle of install posses.
I don't know which part of the solution is accepted, but I'm facing the same problem with AIR-AP1832I-E-K9. The first part with the upgrade (currently on 8.5.161.0) doesn't work and the problem remains.
The second part of the solution (open RMA) works, but I got tired after 30-40 RMAs.
Does anyone knows what's causing the problem? Is there a solution other than replacing the malfunctioning devices under warranty (our warranty soon will expire)?
The accesspoints have a "lifetime" hardware warranty, so for 10 years after buying it you can RMA them.
Thanks for your answer patoberli. I didn't know that they come with lifetime warranty, and now I'm a bit relaxed.
However, this isn't a solution for the problem I have. At the moment I have 6 access points with this problem, all mounted in different buildings, some of them are pretty high (4-5 meters, 12-15 feet). This 6 APs stopped working during the last 2 months (while the University where I work is under lockdown). Since we installed them (almost 3 years ago), we had this problem with more then half of the APs (we have 50 APs). So, up until now I had to replace roughly 30 APs.
I was wondering if someone has idea what is causing this problem, and if there's a workaround. Currently I'm running APs in CAPWAP with Virtual WLC 8.9.100, but I had problems with all the previous versions I tried and also with the Mobility Express installations. The APs are connected to Cisco Catalysts (3560, 2960, 2960x) ports, some of them are PoE, some PoE+, and some are connected with power adapters. Most of the APs are connected to gigabit ports, but unfortunately, some APs are connected to 100 Mbps ports. There's no obvious common reason for the failures.
I fear you might have a bad hardware batch. I suggest to open a new TAC and see if Cisco has to say something. I couldn't find a field notice for this problem, but maybe they have some internally known bugs. It's absolutely not typical to happen.
Regarding software, downgrade to the latest 8.8 or upgrade to 8.10, 8.9 will not receive any further updates. I suggest 8.8.130.0 or even 8.5.164.0 for stability.
Thanks @patoberli, it's exactly what I was suspecting. I'm going to open a TAC case.
Hi Jordan,
Hope all is well.
How did this go? Any update from Cisco on this matter.
I haven't open TAC case yet. I'll post any updates once I open the case.
Hello Jordan,
Thank you for the great feedback. This would really help some of us having same issue.
