Reconfiguring WLC's Management Interface
crange
Level 2
Level 2
NAME: "Chassis" , DESCR: "Cisco 5500 Series Wireless LAN Controller"
PID: AIR-CT5508-K9
Product Version.................................. 8.5.160.0
I am trying to change manegement Ip address, Mask and gateway. But facing error Below is command which i am using and error facing.
(Cisco Controller) >config interface address management X.X.X.X X.X.X.X X.X.X.X
Request failed – Active WLAN using interface. Disable WLAN first.
I disable all WLAN using the following commands
(Cisco Controller) >config wlan disable all
I valited that all Wlans were disable, but when I tried to reconfigure the interface, I get a different error because management interface is configure into EoGRE tunnel
Could you let me know what is the way to solve this configuration, I couldn't find a complete procedure to do it
Thanks.
15 Replies 15
Mark Elsen
   - Show the exact error message (tx) ,
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Thanks for your reply, I dont have GUI access, I tied to do it using the CLI but Looks like there is a Wlan active but I disable all of them
Hi @crange
Go to the CONTROLLER tab, and on the  left side, look for Tunneling. And under Tunneling click in EoGRE.
In Interface config, must be management. Change to something else and apply. Then, try to edit the IP address again.
That´s something. Never saw that before.
Can you reload the WLC?
I did it.
well, sounds odd but I would try to upgrade the WLC. It does not make sense. You have 4 WLANs, all of them are disabled but the WLC keeps saying it has WLAN UP. Sounds like a bug.
If you have the possibility, open a TAC could be another way out.
Sounds Good! thanks!! I will let you know once I get an answer!!
Leo Laohoo
Disconnect the WLC uplink and change the Management IP address using Console or Service Port (GUI).
Hi Leo,
I did it but I got the same result.
  - You could save the configuration , factory reset the controller , have  basic setup on it with management ip as intended , then restore the configuration  , leave the items out of it related to the mangament interface setup ,
 M.
       Beauty and terror
      Just keep going
       No feeling is final
If you were able to disable the uplinks, then why didn't you turn off all the WLAN, change the Management IP address and turn the WLAN back on?
