Reconfiguring WLC's Management Interface
crange
NAME: "Chassis" , DESCR: "Cisco 5500 Series Wireless LAN Controller"
PID: AIR-CT5508-K9
Product Version.................................. 8.5.160.0
I am trying to change manegement Ip address, Mask and gateway. But facing error Below is command which i am using and error facing.
(Cisco Controller) >config interface address management X.X.X.X X.X.X.X X.X.X.X
Request failed – Active WLAN using interface. Disable WLAN first.
I disable all WLAN using the following commands
(Cisco Controller) >config wlan disable all
I valited that all Wlans were disable, but when I tried to reconfigure the interface, I get a different error because management interface is configure into EoGRE tunnel
Could you let me know what is the way to solve this configuration, I couldn't find a complete procedure to do it
Thanks.
15 Replies 15
Rich R
