Showing results forĀ
Search instead forĀ
Did you mean:Ā
recursive" not deleted -- permission denied
please help
TJ-20933766
Sorry about that. I just realized that you're at the ROMMON prompt. Since you're in ROMMON, the syntax is different. I know how to delete files within the directory but not the directory itself. To delete the image within the directory, use:
ap: delete flash:ap3g2-k9w8-mx.153.JPK/ap3g2-k9w8-mx.153.JPK
Alternatively, if you want to delete everything in flash, you could use the following command:
format flash:
Then you could upload the another image via TFTP
5 Replies 5
TJ-20933766
your syntax is incorrect. Because you don't have have a space between "/force" and "/recursive", the AP is confused as to what you are trying to do. Add the space and try the command again
delete /force /recursive flash:ap3g2-k9w8-mx.153-3.JPK
okay i will try again
ap: delete /force /recursive flash:ap3g2-k9w8-mx.153-3.JPK
Are you sure you want to delete "/force" (y/n)?y
File "/force" not deleted -- permission denied
Are you sure you want to delete "/recursive" (y/n)?y
File "/recursive" not deleted -- permission denied
Are you sure you want to delete "flash:ap3g2-k9w8-mx.153-3.JPK" (y/n)?y
File "flash:ap3g2-k9w8-mx.153-3.JPK" not deleted -- is a directory
TJ-20933766
format flash:
thank you for the solution
