Redirect URL after login doesn’t work for Android 12
ri097
I’ve created an SSID with web-passthrough policy. After accepting the terms user should be connected and redirected to the defined URL. Redirection works for win10, iOS and Android 11 users, however when I try to connect any device with Android 12, redirection doesn’t work. There are no certificate errors or errors with connection, it just doesn't redirect.
Rich R
What WLC?
What software version?
What does the config look like?
Are you using public cert which matches DNS name being used?
Have you run debug or radioactive trace and packet captures on the client?
