Redundacy
Hello every one thanks for read me. I really sorry if my grammar is so bad but I'm not  native speaker. I read this topic before
https://supportforums.cisco.com/message/3722746#3722746 But I'm not sure if I can apply this situation in mi case.
I have one Controller 5508 is my Central Office and I have some Ap's working in local mode in my Central Office, additional I have more Ap's in a remote Office they're are working as H-REAP and I can handles across my WLC. Now my enterprise decided bouth another WLC and wants to deploy a active-passive scenario.
This new Controller should manages all the AP's when the central WLC fails... My questions are...
I need to have the same ip addressing on both sites? or they can be different?
I nedd to configure some on my Ap's that are working as local mode, for allow the secondary WLC manage them when mi central WLC fails?
I have several doubts about my ip addressing.
Thanks again for read.
Espero que la información haya sido útil y si no tienes más preguntas recuerda cerrar el topic, seleccionando la respuesta como "Respuesta correcta"
**Please rate the answer if this information was useful***
**Por favor si la información fue util marca esta respuesta como correcta**
It would be like this
WLC1:
Vlan Identifier: 6
Ip address : 10.10.10.2
Netmask: 255.255.255.0
Gateway:  10.10.10.254
Primary DHCP Server : 10.10.10.254
WLC2:
Vlan Identifier: 6
Ip address : 10.10.10.3
Scott
Help out other by using the rating system and marking answered questions as "Answered"
-Scott
10 Replies 10
Scott Fella
Well typically you have a primary/standby, but I like to have both running with AP's on them.  You would need licenses on the new WLC to allow the AP's to failover, or if you are running v7.4, you can do an N+1 with a WLC HA sku.
Anyways, the prefered method is to have both WLC's at the same location.  The ip address would not be the same but has to be unique.  Here is a doc that explains how redundancy works.
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a008064a294.shtml
I wouldn't go with v7.4 and HA as it is not stable.  v7.4 using N+1 is okay and would cost less, but you have to make sure your AP's support v7.4.  You can find that info here:
http://www.cisco.com/en/US/docs/wireless/controller/5500/tech_notes/Wireless_Software_Compatibility_Matrix.html
Here is a link to v7.4 N+1
http://www.cisco.com/en/US/docs/wireless/technology/hi_avail/nplus1_deploy.pdf
Scott
-Scott
Thank you Scott:
Desafortunatly the WLC must be on different Office. I see the link that you send me and I really aprecciate it to much but I see the 2 WLC are on same subnet. The ip addressing are different one has 10.10.40.0/24 and the other office 10.10.71.0 /24
the procedure could be the same?
Well it just makes it complicated, since your dynamic interfaces will be assigned in the other location and in a failure, the local AP will place user on the local subnet where the new WLC is placed.  So clients will of course bounce and have to obtain a new ip address after the AP's join the new WLC.
Scott
-Scott
Hello Scott.
I have a new scenario, now both WLC are in the same place... I think this is more easy, I have another question. I need to use the same ip addressing for my Dinamyc interface? and just need to change the managment addressing?
Thank your for your answer
Ip address should be unique between any device including the WLC dynamic interfaces.  So yes make sure they are different.
Scott
-Scott
So... When my backup WLC becomes on the central WLC my user en X vlan will change their ip addressing? It means I need two squeme adressing for SSID?
Both WLC's located on the same location should have a dynamic interface on the same subnet.  You are now placing both WLC's in the same location correct?
Scott
-Scott
Hello Scott yes... now both are in the same location let my try to explain better:
For Example  I have a SSID "guest"
In my central WLC I created an Interface called "guest" and its information is this:
Vlan Identifier: 6
My question is in my secondary WLC I need to have this same values? or I need an Diferent values, I mean new:
Vlan Identifier:
Ip address:
Netmask:
Gateway
Primary DHCP Server
I really sorry If my grammar is awful
WLC1:
Vlan Identifier: 6
WLC2:
Vlan Identifier: 6
Scott
-Scott
Thank you so much Scott.
