Regarding DHCP for Lightweight Access Point
shawntls82
I have a 2500 WLC and I'm going to setup DHCP server in 3750x switch, one of the DHCP pool will be issuing ip address for AP. So, in the DHCP pool I should include option 43, am I correct?
If yes, may I know what is the exact steps to configure this? because I'm abit confused over the configuration guide.
If i don't include option 43 then AP will not get IP from the DHCP pool rite?
Thanks.
5 Replies 5
Stephen Rodriguez
Honestly, it depends.  I like using option 43 even if the WLC and AP are in the same subent.
Option 43 just informs the AP of where the WLC is, but the AP will get an address with out it.
you just need to define it under the scope, so for example:
ip dhcp pool Test
network 192.168.1.0/24
default-gateway 192.168.1.1
option 43 hex f104.oaoa.oaoa
In the above, my WLC management address is 10.10.10.10.  So long as you have ip reachability it would work
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
HTH,
Steve
Hello Stephen.
I never hear you can use DHCP option 43 if the AP's and WLC are in same subnet, I'm relative new in this... Can you say me why is better use it?
Espero que la información haya sido útil y si no tienes más preguntas recuerda cerrar el topic, seleccionando la respuesta como "Respuesta correcta"
**Please rate the answer if this information was useful***
**Por favor si la información fue util marca esta respuesta como correcta**
Abhishek Abhishek
As per your query i can suggest you the following solution-
Ethernet ports on Cisco 2500 Series Wireless Controllers do not work as Switch ports (that is, 2 machines directly connected to these ports will not be able to communicate with each other). You should not connect servers like DHCP, TFTP etc. on these ports and expect Wireless Clients and APs to receive an IP address from this DHCP server.
Ethernet ports on the Cisco 2500 Series Wireless Controller should only be used to connect/uplink to an infrastructure network configured as a data interface (management interface and dynamic interfaces) or an AP-managers interface.
If multiple Ethernet ports on a Cisco 2500 Series Wireless Controller are uplinked to an infrastructure switch, you should make sure data interfaces (management or dynamic interfaces) or AP-managers interfaces are configured for these uplinked physical ports. Physical Ethernet ports which are used as an uplink to an infra switch should not be left un-configured. This may result in unexpected behaviors.
Multicast unicast is not a supported configuration on Cisco 2500 Series Wireless Controller. As a result, HREAP APs are not able to receive multicast traffic because HREAP APs only work with multicast unicast.
Hope this will help you.
Abishek,
     that makes absolutely no sense to the question asked.
Daniel,
     Option 43 is always an option to help the AP discover the WLC.  Why is it better? it may not be, but I like to keep my self consistent wtih my deployments.  So I always want to put that option there.
HTH,
Steve
HTH,
Steve
Thanks for your replay Stephen
