Remove All devices from My Device Portal
tstrode01
We have a device portal set up for students to register certain endpoints such as PS4s and XBoxes.  At the end of each semester we want to clear out all devices that are registered in the device portal.  What is the best way to do that?  Is it through ISE, Prime, or WLC?  Is there another method?  What is best practice?
Terry
Rasika Nayanajith
You should be able to create a purge policy on ISE under
Identity Management > Settings > Endpoint Purge
Refer this URL (towards the end)
https://www.cisco.com/c/en/us/td/docs/security/ise/1-3/admin_guide/b_ise_admin_guide_13/b_ise_admin_guide_sample_chapter_01101.html
Rasika
*** Pls rate all useful responses ***
