Repeater not passing data?
inlandkw
Frequent Visitor
Frequent Visitor
I have two 1200AP's set up and am trying to get one working as a repeater for the other. We are doing EAP-TLS authentication for our network, but for the repeater to authenticate I enabled LEAP on the ACS server. I added a user on the ACS for the repeater and entered the information on the repeater access point for the EAP client. When I boot them both up, I can see on the root that the repeater comes up as a repeater and EAP-ASSOCIATED with self as the parent. However, when I try and connect to the repeater I associate fine, and come up with the repeater as the parent but I can't seem to get any data through. I can't ping anything while connected to the repeater, nor can I renew a DHCP IP address. Any ideas?
wong34539
Level 11
Level 11
While in repeater mode the APs ethernet port will be disabled, are you trying to ping some network connected to the ethernet port? If so it will not work.
