Request for Guidance on Telemetry Interface for C9800CL
madhurimuppalla
Regarding the setup of Cisco Spaces Connect for IoT Services with our C9800CL Wireless Controller, we are experiencing an issue with the Data Receiver Application. After re-registering the Data Receiver Application and subscribing to the appropriate topic, we are unable to receive any messages on the client side.
Environment Summary
OS: Ubuntu 20.04
Virtual Setup: C9800CL vWLC hosted in KVM
Client: Bluetooth functionality assumed to be operational on the Ubuntu setup
Steps Followed
  1. We have installed the 17.15 C9800CL vWLC on Ubuntu 20.04 running in KVM.
  2. Following the steps outlined in the Cisco Spaces Connect for IoT Services Quick Start Guide, we completed the following:
    • Deploying the IoT Orchestrator Application on Cisco Catalyst 9800 Wireless Controller.
    • Configured the Cisco Catalyst 9800 Wireless Controller from the IoT Orchestrator.
  3. To register the third-party application, we created the server certificate and attached it in the IoT Orchestrator UI and also generated the API keys.
  4. Then we able to onboard the BLE client, connected, and performed read, write, and discovery using the API example.
  5. Then we registered the data receiver application, registered a topic, and then subscribed to the topic using the API example.
  6. To receive the notification, we executed the mosquitto_sub command in the BLE client terminal but were unable to receive anything.
Thank you .
0 Replies 0
