Restart AP using SNMP
Scott Pickles
Level 7
Level 7
Does anyone know the SNMP command to send a reset to an AP? model 1240/1130 would be preferred.
Scott
Scott,
Follow the procedure listed at the URL below to reboot the AP using SNMP.
http://www.cisco.com/en/US/customer/tech/tk648/tk362/technologies_q_and_a_item09186a00800c263d.shtml#qa4
The 1130 and 1240 both support the OLD-CISCO-TS-MIB and you should be able to use the procedure listed above.
Pushkar
