#RMGR-3-RED WLC SWITCHOVER: [SA] rmgr_sm.c:3243 WLC HA - Switchover Occurred, role changed from Standby to Active, Reason:CP-DP Crash,
guilhermecosta
Guys, I need help, has anyone seen this error before?
7 Replies 7
marce1000
 - A WLC HA failover occurred because the Active controller has crashed. Which controller-model(s) are you using and what is  the current software version ?
M.
I'm sorry, I forgot to put the version I'm using.
System Summary
Software Version 8.0.121.0
Field Recovery Image Version
the controller presented this error and then started with the configuration reset.
I needed to put it on the network and then backup it.
i found this information:
*             Start Cisco Crash Handler                *
Sys Name:     WLC-01
Model:        AIR-CT5508-K9
Version:      8.0.121.0
Timestamp:    Thu Mar 15 17:04:27 2018
SystemUpTime:     249 days 6 hrs 25 mins 26 secs
signal:       11
pid:          1093
TID:          1559765824
Task Name:    emWeb
Reason:     System Crash
si_signo:     11
si_errno:     0
si_code:      1
si_addr:      0x14
timer tcb:      0x42
timer cb:       0x10efb3d0 ('Unknown')
timer arg1:     0x15144138
timer arg2:     0x0
Long time taken timer call back inforamtion:
Time Stamp:     Sun Dec  3 03:57:52 2017
timer cb  :     0x10265a18('Unknown')
Duration  : 770929 usecs, cbCount= 5
Analysis of Failure:
  Software Failed on instruction at :
 pc = 0x11a8c914 (Unknown), ra = 0x11a8c8f4 (Unknown)
  Software Failed while accessing the data located at :0x14
 - Try upgrading your controller software (especially if the problem persists).
M.
I'd upgrade the firmware of the controller.
The Cisco TAC said that my issue is related to this bug:
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCus77368/?reffering_site=dumpcr
and said that I need to do the firmware update.
