Roaming problems after IOS Upgrade
aboschetti
Level 2
Level 2
We have upgrade our APs 1100 from Firmware 123-2.JA2 to new 123-4.JA.
We are using wireless with 7920 (firmware 2.0) and CCM (4.1.3 sr1); after the upgrade we have problems with roaming !!
Should be ok. Need more info.
Kasper Roholt
Level 2
Level 2
Have same problem after upgrading to 123-4.JA running 7920.4.0-01-08.
After upgrading phones to 7920-4.0-01-09 roaming is OK (again)
Need 1.09 firmware or higher to use this AP code version, otherwise roaming will fail.
