Rssi low check
hs08
I enabled RSSI low check for 5Ghz and 2.4Ghz, for 5Ghz set to -67 and for 2.4 set to -65
but why on the client i can see there are still many client with rssi lower than -65 and 67?
5 Replies 5
Mark Elsen
             - You don't mention controller type and software version currently using (=?)
 M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
Hi @Mark Elsen
Currently i use WLC 2504 with 8.5.182.0 software version
 - As per https://www.cisco.com/c/en/us/support/docs/wireless/wireless-lan-controller-software/200046-tac-recommended-aireos.html
                  Check it out with : https://software.cisco.com/download/specialrelease/2702eede2b47a5c3bb40795bbe836af6
  M.
What that mean? Given url only say about recommended software version
 - The latest advisory for  your controller type as mentioned in the document being :
    is always advised on the older aireos controllers these days as they are being phased out and TAC support is diminishing  (support fading). Check if that can help for your issue too.
 M.
