Same SSID with different dhcp scope on same controller
csco10865546
Level 2
Level 2
Hello Guys,
I have a 5508 WLC controller at the HQ with the employee ssid ,the dhcp scope on the ssid is 10.120.0.0/16 network.
However,I want this same ssid to be brodcasted to a remote site using HREAP access point but with  different dhcp scope 10.102.0.0/16.
I have tried creating another interface for the remote site with a different dhcp scope(10.102.0.0) but the controller wont allow me create another wlan with same ssid that existed before to apply the new interface created for.
Attached is a diagram that explains the topology,thanks for your help ....
Surendra BG
You can go for the feature which is called as HREAP local switching!! here is the link..
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a00807cc3b8.shtml
Please dont forget to rate the usefull posts!!
Surendra
Surendra BG
