Schedule WLAN configuration changes using CPI
JASON SIMMONS
Level 5
Level 5
I need to make some configuration changes to a WLAN on our controllers after hours, yet I cant figure out how to do it.  The controllers are running v 7.3.101.0 (5508s & 2504s), CPI is version 1.3
When I go to Configure > Scheduled Configuration Tasks > WLAN Configuration I get the following message
No saved task exists.  You can schedule WLAN task for required Controller from " Configure > Controllers > COntroller IP > WLANs > Wlan configuration" page.
When I go there I dont see any options to schedule a change.  When I make configuration changes to a WLAN and click save I get a warning messages that leads me to believe that the changes will be effective immediately.
Am I missing something?
