Scheduling a powercycle of Wireless Access Points...
rcampb3ll
Hello.
In our environment we have two Cisco 5500 Series Wireless LAN Controllers, fourty-six Cisco 3500 Series Access Points, and use Cisco Wireless Control System for management.
Is there a way to schedule all forty-six Access Points to powercycle weekly during off-business hours?
Any guidance would be greatly appreciated.
Thanks!
ok, in the AP templates there is a checkbox to reboot the AP.  So same scenario, just check the box and schedule it to run at whichever time you want.
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
HTH,
Steve
5 Replies 5
Stephen Rodriguez
Are you looking to turn of the AP so that they don't offer services?
You can use WCS templates to schedule the radios to be disabled, and another to enable them.
HTH,
Steve
HTH,
Steve
Thanks for the reply Steve.
We are looking for a reboot of the Access Points, not to turn them (or their services) off.
HTH,
Steve
HTH,
Steve
Thanks again.
I'll look into the AP templates and see if I can get it figured out. As this is my first foray into WCS, there will be a bit of a learning curve I'm guessing.
If you don't fancy this, there is another way of doing this and it's via Cisco's EnergyWise.  Let's say you want to reboot your AP at midnight:
!Global
energywise domain security shared-secret
energywise importance 60
!  Time Range
time-range ON
absolute start 00:00 01 February 2013
periodic daily 0:01 to 23:59
time-range OFF
periodic daily 0:0 to 0:01
!  Interface
interface GigabitEthernet0/1
energywise level 10 recurrence importance 70 time-range ON
energywise level  0 recurrence importance 70 time-range OFF
