SEND_ALERT: Send FATAL for AP 3502i
Hello everyone. I am having difficulty registering my 4 3502i access points on my WLC 2500 controller. after console access in an AP, I see the fatal send message. I tried to bring the controller date back to 2018, 2012, 2026 but until the controller rejected the AP. I even downloaded the latest version 8.5.182.0 of IOS but still no success. Thanks for your help
*Jun 7 23:13:14.457: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*Jun 7 23:13:14.482: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
*Jun 7 23:13:15.482: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
*Jun 7 23:13:22.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 11.11.11.5 peer_port: 5246
*Jun 7 23:13:22.251: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully peer_ip: 11.11.11.5 peer_port: 5246
*Jun 7 23:13:22.251: %CAPWAP-5-SENDJOIN: sending Join Request to 11.11.11.5
*Jun 7 23:13:40.308: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 11.11.11.5:5246
*Jun 7 23:13:40.399: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to administratively down
*Jun 7 23:13:40.399: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to administratively down
*Jun 7 23:13:40.402: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
*Jun 7 23:13:40.433: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to up
*Jun 7 23:13:41.405: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*Jun 7 23:13:41.424: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to down
*Jun 7 23:13:41.431: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to reset
*Jun 7 23:13:42.418: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0,
Mark Elsen
 - Have the controller back to current time, date and use NTP. Then if this persists also check the controller-logs when this happens.
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Mark Elsen
 M.
       Beauty and terror
      Just keep going
       No feeling is final
thanks I will try
Rich R
Have you followed ALL the steps in https://www.cisco.com/c/en/us/support/docs/field-notices/639/fn63942.html in the correct order?
Read through very carefully.
