Setting up Cisco AIR-LAP1142N - A - K9
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
07-25-2023 06:41 PM
I recently purchased a Cisco AirLAP 1142n ap used from Ebay. I have yet to figure out how to console in to implement some basic configuration. I have no idea what the ip address or SSID information is. My console cable is running from my iMac and works perfectly fine for my other Cisco devices. Consoling the WAP just gives a blank screen and after the WAP boots up it goes through a green, red, and amber color cycle. I have searched around online and still haven't figured out what the color cycle indicates. Does anyone know?
Jonathan
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
07-25-2023 06:58 PM
That indicate that this AP is looking for a Wireless lan controller. This is not good bacause you need a standalone AP. This AP will not allow you to co figure anything without a WLC.
But, you should be able to see the information on screen. This is another problem.
It is possibe to convert AP from this mode to autonomous but it would require you to download the proper IOS. And, of couse, né able to access the device.
The problem of not accessin the AP is probaly related to the console cable. I had cable that was able to access any device but failed accessing an AP.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
07-25-2023 07:03 PM
Thank you, this is becoming more clear. So I can convert my lightweight access point into an autonomous access point through an IOS upgrade IF I can get a successful console connection?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
07-25-2023 07:20 PM
Yes. As soon as you get access you can setup a TFTP server on your PC , put an IP address on the AP and convert it from capwap to autonomous.
You can use the command "capwap console cli" then, you can use the command "configure terminal" and to put an IP address use
interface bvi 0
ip add 192.168.1.1 255.255.255.0 (Example)
This way you will be able to ping from PC to AP and vice-versa. AFter that, you are able to transfer an IOS to the AP.
But, after you succeed connecting to the AP let me know. Lets confirm if that AP is really a capwap AP as I am thinking it is.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
07-25-2023 07:19 PM
Can you run me through the process of how I would make a cisco ap autonomous?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
07-25-2023 07:22 PM
answered above.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
07-25-2023 07:24 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
07-25-2023 07:27 PM
This is great thank you!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
07-27-2023 05:40 AM
As Flavio said Cisco APs are very fussy about console cables - they only work with certain cables - generally those using genuine (not counterfeit) FTDI chips will work.
This one works for me: https://www.amazon.co.uk/gp/product/B07MYQPYKR but other similar cables may too. Be sure to check the reviews for the specific cable you buy to make sure somebody has confirmed that it works with Cisco APs.
Please click Helpful if this post helped you and Select as Solution (drop down menu at top right of this reply) if this answered your query.
TAC recommended codes for AireOS WLC's and TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's, Best Practices for 9800 WLC's and Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
