07-15-2015 10:21 AM - edited 07-05-2021 03:35 AM
I am attempting to set up MESH/Bridging on one of my 5500 WLC's and the unit will not allow (open a page) when I click:
The 802.11a to change the TxPower settings. Is there another setting that must be altered first?
Running
8.0.115.0 |
07-15-2015 06:12 PM
Make sure you enter the ethernet mac address of the APs in mac filter list on the WLC.
Then make the one in your network as RAP (Root Access Point) and the next one as MAP(Mesh Access Point). Make sure that both of them are in proper Line of Sight. The channels for 5GHz would also matter.You might need to tweak the vlan transparent feature in Mesh
Manas Pratap Singh
07-29-2015 09:15 AM
Please check the below guide for the complete configuration, may be these will help you on setting up mesh
Cisco Wireless Mesh Access Points, Design and Deployment Guide, Release 7.0
http://www.cisco.com/c/en/us/td/docs/wireless/technology/mesh/7-0/design/guide/MeshAP_70.html
http://www.cisco.com/c/en/us/support/docs/wireless/aironet-1522-lightweight-outdoor-mesh-access-point/113678-wlan-mesh-config-ex.html
07-29-2015 11:06 AM
From the controller Console ,issue the following command.
config ap mode bridge "Name of the AP"
