Setting up WEP on AP350
mcship
We just purchased Cisco AP350 and I'm wanting to use WEP but when I go to the security--Radio Data Encryption (WEP). I get the following message at the top of the screen "Use of Data Encryption by Stations is: Not Available
Must set an Encryption Key or enable Broadcast Key Rotation first " I then when to Network ports---Ap Radio---advanced and put 900 in the "Broadcast WEP Key rotation interval (sec):" Once I did that I went back to security and the options of "no encryption, optional encryption, and full encryption" were there but when I put in a key it would give me an error message saying it was an invalid field. Any idea what I'm doing wrong?? I don't know if I want to enable the broadcast key rotation or not and I can't find any other location to put in a Encryption key...Thanks in advance.....BMC
tepatel
Here is the url which discuss "Configuring WEP" in detail
http://www.cisco.com/warp/public/102/wlan/confwep.html
That procedure is known good and lets see it works for you or not..Tejal
WEP Encryption for Aironet 352 using iPAQ
In the ACU there is a setting named WEP
This Setting has Two values
Dissabled and Enabled
Now, I want to know, when enabled . . . .
A: Can it handle 128bit Encryption
B: If not can it Handle 64bit
C: If not what is the point in having WEP
D: If it can, then where do I put my 4 Keys for 64bit or my Hex key for 128bit?
I am pretty sure that I am up-to-date with all the new drivers to the Aironet 352 for the Win CE, and any new firmware for the PMICIA card that I may require.
I have my CEM (Client Encryption Manager) but Any type of password/key I put in here, I always get an error message stating "Please Enter The Correct Password"
Is this where I am to put my Hex keys? Or even a PassPhrase? Yet I have tried both, and still get the same message.
I am puttin the Hex key in, in this format:
112233445566778899AABBCCDD
Is this Correct?
Or does it need to be in a different layout?
All SSID are the same, so there is not a problem there.
Everything works fine untill the WEP is Enabled on the Access Points/Bridges.
If anyone can help me with this, I would be most grateful.
