Setup Vendor Wireless LAN
metzj
Visitor
I understand and already have working a two VLAN wireless SSID. One for Internal Users and the Other for Vendors. My question, How can I make it easy for vendors of various sorts to come in and hookup wirlessly with ease but yet still maintain encryption for there protection?
Thank You,
... Feel free to ask more questions.
scottmac
Level 11
Level 11
What is your current setup for the vendors?
Is your RF pattern designed to limit the amount of signal & availability to the area of need (versus blasting waves out to the road, sidewalk, and parking lot)?
Captive portals tend to be the easiest, WPA-PSK would probably be OK, at least for vendors that frequent your organization.
What have you got now?
Let us know
Scott
Scott,
Thanks for the help. We currently are doing WPA-PSK. Here is our problem. Most of the vendors have the cisco wireless card and it does not do WPA-PSK to the best of my knowledge. Windows wireless zero certainly does and most other cards do the same. Any suggestions would be appreciated.
Thanks Again,
Joel
Hi Joel,
You have a couple of options:
1. Use WPA Migration mode to allow both WEP and WPA-PSK clients to associate to the same VLAN/SSID. The configuration might look like the following:
dot11 ssid Guests
vlan 10
authentication open
authenication key-management wpa optional
wpa-psk ascii whatever
Interface Dot11Radio0
encryption vlan 10 mode ciphers tkip wep128
encryption vlan 10 key 1 size 128bit 1122..
ssid Guests
The problem with this option is that some clients do not understand the options and may not work. Also, you'd be offering a "less secure" encryption option, so it may just be simpler to go with straight WEP (see option 2).
2. Go with straight 40 or 128 bit WEP. 40 bit WEP tends to work universally among clients and is a simpler configuration task (10 hex characters) versus 128 bit (26 hex characters).
Hope this helps,
Ben
2.
