signal strength question
muhsi_2015
A smartphone is hardly getting RSSI -67 dBm while doing a survey .So Its sure that the second strongest signal should be less than -67 ,
So do we need to care  about this ?.
Does it means the  smartphone struggle when roaming ?
Sandeep Choudhary
Yes smartphone will have problem while roaming if you have not done the proper site survey.
For voice deployments, it is recommended that the cell edge should be at -67 dBm with 20 percent overlap.  VoIP solution at -67 dBm (perhaps the most widely-used value for VoIP deployment if I had to choose one), while another may say -70 dBm. In most cases the values will differ only by a couple dB.
A common practice is to design for signal strengths in the -65 to -70 dBm range with two or more APs overlapping throughout the coverage area.
Dont forget to rate helpful posts
