Simple DHCP question
j.pewarski
Community Member
Hi all,
Im configuring a wireless network, and currently my network works but I have a employee ssid, and guest ssid.
My employee network works fine, and I can pull a dhcp. When I connect to my guest ssid I am still pulling from my employee DHCP server. How do I use the DHCP over ride field to correct this? do I have to set another DHCP server on my router, and configure the DHCP over ride to the 10.0.0.1 server listed below?
say for the guest internet
10.0.0.1 is the server
10.0.0.10 - 50 is my pool
8 Replies 8
Sandeep Choudhary
You can create a DHCP scope in WLC for guest access and let employee get ip from DHCP server.
If you are create DHCP on wlc then you must change the DHCP ip on dynamic interface page.
Yes that is what I was trying to go for originally but it did not seem to work. How do I properly configure this to work as you stated above. I do apologise for my ignorance this is my first deployment with dual DHCP pools. normally my guest network is a completely seperate network.
Choose Controller > Internal DHCP Server > DHCP Scope to open the DHCP Scopes page
enter all the detaisl for guest ssid.
then enter DHCP address on dynamic interface :
enter the controller ip in dhcp server address box for guest dynamic interface.
http://rscciew.wordpress.com/2014/01/22/configure-dynamic-interface-on-wlc/
Dont forget to rate helpful posts
ok that sort of helps:
Does the below screenshots look correct? instead of creating another interface I used the virtual interface. Will this work?
New Bitmap Image 1.bmpNew Bitmap Image 2.bmpNew Bitmap Image 3.bmpNew Bitmap Image 4.bmp
These pics are not clear at all..
I will recommand to use a different dynamic interface not virtual interface.
Stephen Rodriguez
What interface is your guest WLAN linked too?
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
HTH,
Steve
Ali Aqrabawi
use separate interface for the guest WLAN , in this interface the DHCP server ip will be the WLC management interface , creat an internal DHCP scoop for the guest WLAN ,
kaaftab
Level 9
Level 9
check the following link for dynamic interface configuration
http://mrncciew.com/2013/02/27/configuring-dynamic-interfaces-on-wlc/
