Single Wireless Controller - 2 Diff networks
khan300
Level 4
Level 4
I have a requirement where I have 2 Physically separated networks. I want to use 1 controller and connect both the networks to this 1 controller with 2 diff SSID's.
Is that even possible? As far as I know we can connect 2 diff networks as long as they are connected through WAN or in diff VLANS via H-REAP (Flexconnect). But these network are not even connected via WAN.
If its not possible that what could be a solution to make it possible.
17 Replies 17
Can we just allow the WLC management address to pass through the firewall ? If we do that i think the problem will be solved.
You will also need to allow the wireless client traffic to pass through as well. It will be dumped on the wlc on the one side ..
Please check out the new Desing, Previously both networks were separated now we have a switch in between the 2 networks (guest & business). Should the VLANS be configured on the NEW switch or should it just carry the VLANS from the 2 networks which are separated by a Firewall.
