SNMP configuration for EWC
Torken
Hello to all,
I want to monitor my EWC from an external monitoring server (Zabbix Server). I am used to working with SNMP. I would like to monitor information that I can find in the dashboard GUI menu.
The problem is I can't find any GUI menu to configure SNMP as this link :
https://www.cisco.com/c/en/us/support/docs/wireless/catalyst-9800-series-wireless-controllers/214286-managing-catalyst-9800-wireless-controll.html
I also tried to find a command in CLI, but nothing interesting appear :
EWC#snmp ?
  get       generate an SNMP Get request
  get-bulk  generate an SNMP GetBulk request
  get-next  generate an SNMP GetNext request
  inform    generate an SNMP Inform request
  set       generate an SNMP Set request
EWC#snmp?
snmp
I don't find any information about monitoring an EWC on Internet (maybe I did wrong research)
AP : Cisco 9115AXI-E
Version : 16.12.4a
J.
marce1000
 - In the CLI did  you try snmp-server ? , I mean type the full word 'snmp-server' and check if  you get command options when using '?'
 M.
Ok, I wasn't in configure mode... (I am not used to configuring WC, first time)
EWC(config)#snmp-server ?
  accounting           SNMP Accounting parameters
  cache                Enable SNMP cache
  chassis-id           String to uniquely identify this chassis
  community            Enable SNMP; set community string and access privs
  contact              Text for mib object sysContact
  context              Create/Delete a context apart from default
  drop                 Silently drop SNMP packets
  enable               Enable SNMP Traps
Why I can't find the GUI interface ? (i want to know only to complete my knowledge)
It's well possible that this hasn't yet been implemented on the GUI. Often the full feature set is only on CLI and a reduced one on the GUI.
