SOHO wireless authenticating to HQ IAS
aamercado
Level 4
Level 4
HI
871-netgear-dslmodem--internet-HQ vp3k-IAS
Requirements:
1. Soho user should be able to use the same ssid at home and at work
Background:
1. client is windows embedded with wireless profile setup as open/wep/key automagic/peap/no server cert/ms-chapv2
2. Ezvpn is working as IAS can ping the 871 soho so IAS has a client config for the 871 hostname/ip add with shared pwd and we tried using both Radius-standard and Cisco.
On deb aaa authen, I see the user's laptop ip hitting the ias ip to try to authenticate but not sure why it fails
Any help would be appreciated. TIA
smalkeric
Level 6
Level 6
Did you try this open authentication and WEP? does it work? Because if it fails with IAS there could be some configuration issue on the IAS.
