Solution for WLAN Multi-tenant solution
ttbotsalo
Visitor
I need help with the design for multi-tenant wlan solution. The tenants will be sharing the LAN, WLAN & IPVoice network devices.
TrickTrick
Level 6
Level 6
Hello Sir,
did you find any ideas or solution to this you can share ?
Thanks in advance
rm760
Level 4
Level 4
I support multiple offices and buildings with this scenario.   Seperate VLANs for each for DATA, Voice, corp wireless, and guest wireless.  Billing is two fold CDR for call accounting and then each pays a portion of the monthly services offering total.
