Some APs are not joining the controller
Actually I am facing issue that some access points are not joining the WLC and I got this message
DTLS-3 HANDSHAKE FAILURE:openssl dtls.failed to complete DTLS handshake with peer SSHPM-3-GENERIC_CERT_ERROR
and i check cisco device certificate which all pointing this issue to certificate and found it is still valid and will be expire after couple of months
BY the way i have 2 controllers in 2 sites
AIR-CT5508-K9 8.5.161.11
AIR-CT8510-K9 8.5.161.11
and this version mentioned in
Field Notice: FN - 63942 - Wireless Lightweight Access Points and WLAN Controllers Fail to Create CAPWAP Connections Due to Certificate Expiration - Software Upgrade Recommended
could be the issue even though certificate is valid ?
also one more thing that some access points are joined to controller
   >...one more thing i was about to use manual clock to previous date as i saw solution but i found that certificate is still valid and maybe will not help am i right ?
      - My argument is the same as in my initial reply ; it is simple to test by setting the time back (too) ; if you fear security issues then this option is probably better ,
 M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
5 Replies 5
Mark Elsen
 - Well , if it is the issue you may verify by using the workaround commands anyway :
                 config ap cert-expiry-ignore mic enable
                 config ap cert-expiry-ignore ssc enable
 (ignore the color change , not relevant)
 M.
Thank you marce1000
if you use these commands going to ignore the negotiation by certificate ?
if so is it secure to enable these command or will face attack issues ?
 M.
Is there any command to check certificate in access point
connect the console cable to AP and capture the logs
some Filednotice :
https://www.cisco.com/c/en/us/support/docs/field-notices/639/fn63942.html
BB
