ssh not working after Wireless Controller 5520 upgrade 8.10.112.0
sejelmohajj
ssh not working after Wireless Controller 5520 upgrade to 8.10.112.0, whereas Telnet and HTTPs is working fine.
2 Accepted Solutions
aleopoldie
Level 3
Level 3
Hello Sejelmohajj,
I recently upgraded a WLC 5520 to 8.10.112.0 and didn't face that issue.
Can you show the output of "show network summary" command ?
Thank you,
Léo
I encountered the same issue today after upgrading 5520 WLC to 8.10.112.0. As SSH client I was using SecureCRT and, trying to connect, I received the message
The server has disconnected with an error. Server message reads:
A protocol error occurred. Bye Bye
For SecureCRT I find that I have to change the "Key exchange" with "ecdh-sha2-nistp256". You can find the solution at the following link
https://forums.vandyke.com/showthread.php?p=53113
With Putty client, I didn't have any issue.
So, probably, with the firmware 8.10.112 it is changed the key exchange protocol in ssh connection and with some client you need to change settings manually.
aleopoldie
Level 3
Level 3
Hello Sejelmohajj,
Thank you,
Léo
How if he cannot ssh...?
I face with the issue as well.
Also we face with wifi issue, after removing copper cant connect to wifi...
