ssid access control with WPA Ent and RADIUS author
r.spiandorello
Hi, I'd like to control the ssid requested in WPA Enterprise with RADIUS authorization: how to ?
Is there an attribute in RADIUS IOS or Cisco Aironet ?
thanks
Scott Fella
Depends on what you are using for a radius server.
Here are some links that might help.
http://www.cisco.com/en/US/products/ps6366/products_configuration_example09186a00807917aa.shtml
http://www.cisco.com/en/US/products/ps6366/products_configuration_example09186a0080921f67.shtml
-Scott
I use Cisco Secure ACS 4.2 but in the document I cannot find the authorization RADIUS attribute to control the ssid (or vlan) selected by the user.
Could I use the same as 802.1x wired vlan assignement, IETF 64, 65 and 81 ?
thank you in advance
