SSID assignment
j-shearer
Level 3
Level 3
We plan on implementing a WLC4402/1252 APs at one of our locations. Currently we use "fat" 1242 APs in selected areas and also deploy MS-PEAP using a Microsoft RADIUS server. We would like to have the ability to assign SSIDs based on Active Directory user logins while keeping MS-PEAP in place. I saw some documentation that showed the WLC using a Microsoft RADIUS server for dynamic VLAN assignment. I am wondering if there is anyway to assign SSIDs as well VLAN based on AD user credentials using the WLC. Or perhaps the dynamic VLAN assignment is enough?
Any information, docs, examples configs, etc would be greatly appreciated. Thx.
Joe
Jagdeep Gambhir
Level 11
Level 11
Joe,
Please see this link,
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a00807669af.shtml
If EAP and SSID-based authentication are successful, the user is allowed to access the WLAN or else the user is disassociated.
~JG
Do rate helpful posts
Rob Huffman
Hi Joe,
I think your last statement is correct 🙂 For what you are trying to do Dynamic Vlan Assignment should be all you need. The SSID portion becomes unnecessary when using this config.
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a008076317c.shtml
Hope this helps!
Rob
