ssid for wism-1 controller and 5760 wlc is disconnecting after one hour
for wism-1 controllers and 5760 wlc
when a client  connected to the ssid for a same controller(wism or 5760) the connectivity is getting disconnected for every one hour.
after client reconnect the ssid  of same controller it working but one hour it is getting again disconnected then client again reconnect the ssid
2 Accepted Solutions
Leo Laohoo
Is Session Timeout enabled?
Thanks for taking the time to rate our posts.  :)
8 Replies 8
Leo Laohoo
Thank Leo Laohoo,
it already enable but same problem of disconnecting ssid .the session time out enable screen shot is  enclosed with attached file
Go to the settings for the SSID > Advanced.
Session Timeone settings is there.
Thanks Leo Laohoo,
it already enable
enable session out 1800
Thanks Leo Laohoo,
please advice what is problem disconnecting ssid again has to connect the ssid
Disconnecting after the Session Timeout has been increased?
How about the User Idle Timeout?
Thanks Leo Laohoo,
i am not to find user idle time out in wlan .
the wlan advanced screen shots are enclosed with attached file
