SSID Guest
nstr1
Level 4
Level 4
I have a requirement.
I need to configure a catalyst 9800 L-C with a SSID Guest then this SSID Guest will be with your own internet link.
And the rest of SSID will work with another internet link.
How i can configure the SSID Guest ???
Just make sure that both SSIDs are using different VLANs. The guest-VLAN is then typically terminated on the firewall and source-based routing sends the traffic to the proper link.
If you found this post helpful, please give it Kudos. If my answer solves your problem, please click Accept as Solution so others can benefit from it.
Is there any guide you can share please
I have never set this
