SSID which configured in device disappears automatically and latency goes high.
Vijay Gond
Hi Team,
We have installed Cisco Controller with 22 AP's with one of our client.
When we connected through AP the gateway which is configured in L3 switch pinging with high latency(File attached).
We have configured multiple vlan, the SSID which configured in device disappears automatically and after few second it again visible.
Kindly suggest your expertise o resolve the issue asap.
Vijay Gond
Rasika Nayanajith
What is your WLC model & software version running on it ? If possible post "show sysinfo" output from your WLC.
Did you notice this issue with all client types or particular clients only ?
Rasika
WLC Model No-2504,
System Information
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 8.3.102.0
Bootloader Version............................... 1.0.20
Field Recovery Image Version..................... 7.6.101.1
Firmware Version................................. PIC 20.0
Vijay Gond
Sandeep Choudhary
Try to download& upgrade SW on WLC.
Download Link: https://software.cisco.com/download/release.html?mdfid=283848165&flowid=24841&softwareid=280926587&release=7.4.150.0&relind=AVAILABLE&rellifecycle=MD&reltype=latest
Dont forget to rate helpful posts
