ssid
dkblee
Level 7
Level 7
hi! i'm using cisco ap1240 on lightweight and connected to cisco 55xx controllers. is there any command for me to login into the ap to check what ssid is it running? thx
Surendra BG
Hi By default, all the WLANS will be broadcasted on to the LWAPP if we are using DEFAULT AP Group configuration on the WLC.. so no need to worry at all.. yo can test that using your laptop for searching the wireless connection.. you can see the SSIDs..
You can enable telnet option to the AP from the WLC by using the command
config ap telnet enable and then you can telnet to the AP and issue the command "show run" on the AP
OR
enable telnet for the AP using config ap telnet enable and from the WLC cli issue the AP command..
Debug ap command "show run"
This may show but most of the time this will show the crypto keys..
lemme know if this answered your question.. pls rate the usefull posts.
Surendra
Surendra BG
