Standalone to LWAPP
Ibrahim Jamil
Level 6
Level 6
Hi Folks
we have unifed wireless lan in our enterprise,recently we got an automonous ap now if u add it to our network did the wlc convert it from standalone to LWAPP,or i should do it manuly then put it tin the same vlan like the controller..
what are the steps to convert it to LWAPP?
how to mount it on the ceiling,i mean the base for this AP,our Antena in the long one
Surendra BG
If you have multiple APs then you can use the LWAPP conversion tool which can be downloaded from cisco site.. the other way is to use the manual process by using archive download-sw comamnd...
Here is the doc that i have written on the conversion
https://supportforums.cisco.com/docs/DOC-14960
And here is the link which tells about using the tool.
http://www.cisco.com/en/US/docs/wireless/access_point/conversion/lwapp/upgrade/guide/lwapnote.html#wp157192
Lemme know if this answered your question!!
Surendra
Surendra BG
I have one just AP,how to do it manulay then added to WLC
If you just have one AP then do it manually.. my previous post has the document that will help you!!herea it is again..
In this section you can find IOS to LWAPP
Surendra
Please dont forget to rate the usefull posts and mark it as answered if so!
Surendra BG
