Technical Reference 9800 Best Practices Guide contains wrong pictures
Gehrig_W
Level 6
Level 6
Hello Cisco-WLAN-Experts,
while I was looking through the following document regarding trustpoint information
https://www.cisco.com/c/en/us/td/docs/wireless/controller/9800/technical-reference/c9800-best-practices.html
I found the following wrong pictures, which have nothing to do with trustpoint, but show confusing Mobility infos instead:
In this case I would better show picture from:
Configuration -> Security -> PKI MAnagement -> Trustpoint
In second case, I would better show following picture from
Adminstration -> Device -> Redundancy
Please check and correct this central Best-Practice-Guide for 9800-WLCs.
Thank You
Kind rregards
Wini
5 Replies 5
Can you more elaborate
MHM
What shall I elaborate more ?
The pictures shown are in wrong context. They show mobility information instead of the information mentioned in the acompaning text.  For example in case of second picture the wording mentions "keep-alive-retries" and "higher priority". But these values cannot be found in the shown picture. The information can be found in the path I added instead.
Greetings
Wini
P.S: Another wrong picture shown in Your Best Practice Guide for the 9800-WLC can be found here:
The text is talking about this screenshot instead, which You can finde under Policy Profile -> Mobility in the 9800-WLC.
The picture showing advaced EAP-values is simply wrong when speaking about Mobility.
Please improve.
Kind regards
Wini
Rich R
@Gehrig_W there's no point in telling us about this.  Use the feedback button on that page to report issues with tech docs.
They do get read and forwarded to the document owners and you will usually get a confirmation email to say that.  How quickly they get fixed depends on the document owners but as that one is updated regularly I expect they'll fix it fairly soon.
Be sure to be very specific about the problem so that it is clear to whoever gets it.
Please click Helpful if this post helped you and Accept as Solution if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
AP supported channel lookup: https://apchannels.cisco.com/
Gehrig_W
Level 6
Level 6
Hello Rich,
Thank You very much for pointing me to the feedback button.
I used the feedback button to point Your documentation team to this Thread for details to improve.
To be honest I have never noticed nor used it before.
Let's see how fast a cross-check and update will be published.
P.S.
I thought a cross-check in this forum would happen before and You would forward this afterwards Cisco-internally
to the correct team.
Greetings from Frankonia
Wini
No problem Wini but remember I don't work for Cisco and neither do 99% of the people here so there is no "internal" option for us.  There are some Cisco TAC people who follow this board and respond to some threads but still the quickest way to report a documentation problem is with feedback - I use it regularly.
