Throughput is Always low
Dhikra Marghli
Level 5
Level 5
Hello
I have only one access point outdoor with 4 antenne omnidirectionnel and near c two GSM antenna ...
So throughput is not stable and Always low !!!
I want to know what's paramater (s) that allow increase throughput ( débit) .
Power level , width Channel , turn off band 2,4ghz ....!!
So please i need ftom expert wireless a help and solution that guide me for this problem !!
This access point is Always give 1 Mbits and don't give 30 Mbits !!!!
Thanks in advance
16 Replies 16
To Scott fella ..
I send You a picture that AP installed..
You can check !!
I wait a reply !!
If you aren't able to do this yourself I'd suggest getting a qualified wireless installer/surveyor to check it for you.
