Time problems
dmearsiii
Community Member
I keep getting this message whenever I boot my WLC. I have the Date and Time set correctly but I'm not sure how to set the timezone. Timezone options are Delta: hours __ minutes__
Daylight Savings Enable or disable
The message I keep getting is this:
"Controller time base status - Controller is out of sync with the central timebase."
5 Replies 5
ethiel
Level 8
Level 8
For timezone here are 2 examples:
If you are in Arizona (no daylight savings time so always GMT -7)
config time timezone disable -7 0
If you are in New York (-5 or -4 during DST)
config time timezone enable -5 0
-Eric
Please remember to rate all helpful posts.
dmearsiii
Community Member
Thanks, got that set to my U.S. CST time. Now if I could just figure out why I keep getting the error message, because I don't have a "Central Timebase"???
anyone?
This looks like a radio problem, rather than a time zone problem. Open a TAC case and see what they say.
I'm running a WLC 2006 and 6 Aironet 1242's in lightweight mode. WLC is on the latest version and I've gotten this error with past two versions I have tried as well.
